How do I force unpair/reset/factory reset my Fibaro Relay switches FGS211, FGS221 or FGD211 etc. when my controller with which they were paired is damaged or unavailable.  I was using VERA EDGE earlier
    To add to my original post: I have omitted to mention that I have already tried both recommended methods to unpair  Fibaro Switches (viz) 1. Press and hold the B button for 3 secs after removing all load connections but connected to mains.
    2. Press the Toggle switch connected to S1 6 times ON & OFF.
    The above did not help resetting the device nor uninstall it from its previous association.
    Is there any other method to unpair or Factory Reset the above Fibrao devices.
    How do you know that the reset by method 1 was not performed correctly? Are you trying to pair the device with another controller?
    Yes I tried to pair with the same Vera Edge controller which had to be reset to factory defaults. Now it is as good as a new controller with all settings erased.
    You can use every Zwave controller to reset a Zwave device.
    Just click on your new or by factory reset controller on the remove button.
    Then tripple click the B-button of your Zwave device.
    Your device will bes set back to defauly settings.
    Then you can add this device to your controller as usual.
    I may be an effect of not-being-properly-reset device but also not being able to pair due to distance...
    Be close to the controller when paring.
    However, when trying to reset I would recommend:
    1. keep the button longer than 3 seconds
    2. do not connect anything to S1/S2/Q1/Q2
