Showing results for tags 'factory reset'.
Hi folks! I bought a used Yubii Home, but unfortunately it is still registered to the previous owner, who has since deleted their account. I can log in to the device, but I cannot delete or change the account to my email address. A factory reset cannot delete the local account. I have contacted support but have not received a response yet. Does anyone know how long the average response time is?
- 2 replies
- unregister
- registering device
HC3 not visible in network - How to factory reset without User Interface?
GdB posted a question in Home Center 3
Hello, After a parameter change of a MultiSensor the 'busy indicator' kept circling without saving parameters so I rebooted the HC3. After the reboot all Leds on the front of the HC3 are solid copper except for the Security LED that is blinking. After that manual reboot my HC3 is not visible anymore in software. Nowhere. - Not in the Fibaro Finder - Not in the DHCP Client list of my Router - In the Fibaro Remote Acces website ( https://dom.fibaro.com/cmh/home-center/list) it is visible but in Red with a red cross icon. - In the HC3 configuration interface (COMPONENTS.DEVICE-LIST.MAIN-HEADER.LOCAL-LIST) nothing appears (icon keeps rotating). The procedures in the manual are not clear for me: -1- Using the (+) Recovery button it says "Put in Recovery mode". I did this but how can I see/know it is in recovery mode when I have no User Interface? -2- Hold for xx seconds when network-icon and wif-icon are blinking = they never blink except during startup. They also do not blink after holding the (+) button for 20 s. This means I do not get a change to reset the network settings or switch between Dynamic and static IP. Because the IP address stays invisble I can not find a way to do a factory reset because I have no User Interface. Can someone help me to get my HC3 up and running again? How can I factory reset the HC3 when I have no interface at all? Thank you in advance for your support.- 6 replies
- factory reset
- no ip
(and 3 more)
How do I force unpair/reset/factory reset my Fibaro Relay switches FGS211, FGS221 or FGD211 etc. when my controller with which they were paired is damaged or unavailable. I was using VERA EDGE earlier
Hi, My Home Center 3 suddenly lost connection to my network, and now I can't access the UI. The HC3 is(was) connected to network via both Ethernet and WiFI. I'm assuming that the issue is caused by changes in my network setup. I have tried looking at the recovery page here: https://manuals.fibaro.com/document/hc3-recovery-mode/ and attempted to enter recovery mode, but it still doesn't connect to the network. And since the rest of the recovery options and especially "Resetting network settings" require UI, then i'm stuck. Does anyone know what to do?
Due to numerous requests I decided to describe the recovery procedure for our controllers. Recovery mode allows you to bring controller to out-of-the box state, with the firmware version it was shipped with to you. There is no way to go back to version older that the one you got device with originally. Entering recovery mode on Home Center 2: 1. Unplug your device from power. 2. Hold down the recovery button (with a little "+" on it ) 3. Plug the device back, still holding the recovery button 4. Release button as soon as diodes start to blink from left to right (opposite direction as usually during boot up), enter device configuration page, it should look like this: Entering recovery mode on Home Center Lite: Procedure is the same as in Home Center 2, only difference is that diodes blink in different manner, but you still need to release recovery button as soon as they start to light up. Holding recovery button for too long may cause controller to enter static IP mode. In that case one can attach it to computer directly with RJ45 connector, adjust his own network settings (IP in the same pool and default gateway 192.168.81.1) and perform recovery this way.
