Showing results for tags 'no ip'.
  1. Hello, After a parameter change of a MultiSensor the 'busy indicator' kept circling without saving parameters so I rebooted the HC3. After the reboot all Leds on the front of the HC3 are solid copper except for the Security LED that is blinking. After that manual reboot my HC3 is not visible anymore in software. Nowhere. - Not in the Fibaro Finder - Not in the DHCP Client list of my Router - In the Fibaro Remote Acces website ( https://dom.fibaro.com/cmh/home-center/list) it is visible but in Red with a red cross icon. - In the HC3 configuration interface (COMPONENTS.DEVICE-LIST.MAIN-HEADER.LOCAL-LIST) nothing appears (icon keeps rotating). The procedures in the manual are not clear for me: -1- Using the (+) Recovery button it says "Put in Recovery mode". I did this but how can I see/know it is in recovery mode when I have no User Interface? -2- Hold for xx seconds when network-icon and wif-icon are blinking = they never blink except during startup. They also do not blink after holding the (+) button for 20 s. This means I do not get a change to reset the network settings or switch between Dynamic and static IP. Because the IP address stays invisble I can not find a way to do a factory reset because I have no User Interface. Can someone help me to get my HC3 up and running again? How can I factory reset the HC3 when I have no interface at all? Thank you in advance for your support.
