Deivydas 4
I would like to share my first worth Quick App to control Gree AC Unit (Air conditionier).
This app was developed for my own requirements. I need it to write some scenes which automatically turn on / off ac when temperature is different from set in thermostat.
I would like to say thank for the people who have helped me to find the necessary information. Big thanks to these guys - https://github.com/tomikaa87/gree-remote who had made a lot of work and make the developing process less complicated.
It's doesnt work with fallowing models:
Ok, let's go to inistall it, what you need:
1. Make sure, that your Gree AC Unit have static IP address. Please enter this IP address to QuickApp variable.
2. When IP address is entered, click Pair Device button
3. If pair is success, you are available to control your AC unit
4. Statuses from AC device is updated after each 5 minutes, you can change this
QuickApp version: v1.
Works with: Home Center 3
Take and use it, I'm sure that this app will get updates and additional scenes for automatization
Notes (Updated 2024-05):
Different GREE AC units send different packages to devices, so it cannot be working with every gree ac unit. I'm planning to build another 3 AC units (different gree models in other rooms), when I have it, i'll try to adapt code to more Gree AC devices
Edited by Deivydas29 answers to this question
