shutdown fibaro hc3 from lua
fuser99
I was wondering if HC3 can be shutdown (not reboot) from lua/scene. Could someone point me in the right direction?
Thank you.
11 answers to this question
Thank you.
try this command
fibaro.homeCenter.systemService.suspend()
  • 2 minutes ago, cag014 said:
    try this command
    It doesn't do anything.
    Looks like Fibaro doesn't support their own manual
    You can shut down HC3 by using wall plug. I mean connect HC3 power to Zwave/ZigBee switch (wall plug or binary switch) and send command to turn the switch off.
    In order to start HC3 you'll need manually to turn ON the switch
    Edited by cag014
  • I was hoping for a software shutdown, so I could avoid damaging the HC3.
  • On 11/6/2022 at 12:56 PM, morpheus75 said:
    you can do a software based reboot.
    fibaro.homeCenter.systemService.reboot()
    As I said, I want to shutdown (turn off), not reboot.
