Battery Devices not working / responding
Merlin
I have rooms with several (3 to 5) plugged-in  (i.e. mains operated) z-wave devices which work flawlessly and respond instantly to on and off signals. However in the very same rooms I have (battery operated devices) for example a Fibaro motion sensor and Fibaro Door / Window sensor and these devices do not register motion or opening, if I bring the battery devices closer to the ‘Home Center’ they respond. I have tried reconfiguring the Entire Z-Wave network, so that all devices get a new neighbour list but there is no improvement.
Has anyone else had the same issue and managed to resolve it?
TIA
What brand and model are the mains powered zwave devices? Do they support the repeater function?
You could try installing a something like the Aeotec Smart Switch 6 in a power outlet to act as the repeater.
  • @Tim__
    Hi and thanks for your reply… the mains powered devices I am using are predominantly Everspring Sockets I don’t know if they are repeaters as well or not. I naïvely thought that all z-wave certified products had to act as repeaters by default as part of the protocol.
    Hmmmm, apparently Everspring sockets should work as repeaters.  To diagnose a bit further, you need a tool to see what's going on with the mesh.  I have HC2 and use this scene
      It's helped me solved some wacky mesh issues.  You'll need to find an equivalent for your HC3 though.
