Walli shutter vs RS 3
Milos5888
Hello, I would like to ask you I have replaced my old Becker system to Fibaro. To all local mounting holes I installed RS3
All work fine locally. However I do have one central mounting hole by the door which is wired to every local switch and I installed there WALLI SHUTTER and parralely connected to S1S2 on all local switches. That was not working.
So I let the WALLI SHUTTER without the Q1Q2 connection and tried to control all shutter scenes. Also not working nothing is happening. I can use the scene only from the app not via WALLI SHUTTER SWITCCH
So I wanted to use associations I do have 8 shutter in total but I am able to control only 5 of them. As I am not able to make the assocation its says APPLICATION REJECTED THE REQUEST...
Can you advise how to use WALLI Shutter as central button for all shutter it doesnt matter what way to achieve this ....
THanks
Edited by Milos5888
additioanl info
7 answers to this question
@Milos5888
To use scenes, it is necessary to enable the options of scenes in the settings. Look for parameter 40 and 41.
Now it's simple... write the scene.
eM.
  • On 11/29/2022 at 4:42 PM, Martin_N said:
    @Milos5888
    eM.
    Hello Thank you I did this.
    I can see in history that I clicked the button but again nothing is actually happening Is this something related to nodes / child module...
    @Milos5888
    I'm not sure if scenes and button associations can work together. Do you have a scene defined? Next, you must see in the history that it is sent.
    /monthly_2022_12/image.png.cfe7a1eff355b0066b1141721f6746bb.png" />
    ...and action...
    I'm using a couple of RS3's running with scenes and there's no problem with that.. but no associations.
  • 7 hours ago, Martin_N said:
    @Milos5888
    ...and action...
    @Martin_N Here is my pictures and scenes defined assosications deleted not sure maybew I don't understand the Family  nodes child etc. not sure when tu use ROLLER ID 177 abd when remote/child 177.0.1. for example...
    @Milos5888
    ...and action...
    @Martin_NI have the same I gueaa associations are deleted. Maybe I am not sure how to use the family/nodes/child for example module ID 177 abd when to use remote/child 177.0.1.
    @Milos5888
    Yes, I'm using node x.1 in the scenes.
    There used to be a problem with groups of devices, so I don't use them and I dose each device individually. It's wild, confusing in the block, but you can use lua and then it's a couple of lines. anyway, if you want something more complicated, you'll go to LUA (for example, I have blocking blinds on the basis of open balcony doors indicated by a magnet).
  • 1 hour ago, Martin_N said:
    @Milos5888
    @Martin_N i have All this set up. The scenes is working when used from app.
    i need to set up 1 central button for All shutters either via wires or scenes or associstion nothing is working ať the moment, locally is All good
    @Martin_Nbtw what is difference between the nodes ? Any reason for using x.1 for scenes ? There is nothing about it in manual
    @Milos5888
    Use the node that remains visible after unclicking "hidden devices". For me, it was the x.1 for positioned blinds.
    Device x (package icon) is the global id of the master node. Device x.0 is the master child. There are important settings here, however it is hidden for normal operation. Then you have a device with scenes. And others... will be used in associations.
    I wrote that earlier there were problems with groups. So enter multiple use of the device (each blind separately) in the action field.
