Zigbee lights better over Hue or directly on HC3?
So for now, I have 18 garden lights (Ikea bulbs), connected to Home Assistant by Sonoff zigbee bridge flashed with Tasmota ZHAbrigde.
Works fine, brightness and color temperature can be modified, and I can also set up after power failure behavior - in my case it is 'stay off'.
As I'm going from HA to Fibaro - I need to connect them to HC3 (so far I have HC3L).
I connected one of them to Hue bridge (which is linked to my HC3L - but options are limited - no more settings what to do after power outage - no matter what I do - after the power comes back - this light goes on. This is unacceptable as if this is happening in the night - my garden will start shining like christmass tree:)
So what options do I have ?
- can I link Sonoff/Tasmota bridge directly to HC3? (probably not)
- linking bulbs directly to HC3 via native zigbee - is that works?
- if I but original Ikea central/gate - would that help ?
- any walk around for HUE ? Maybe some scene or QA that will let me setup lights in a way that after power problems they stay off ?
Shame you never got an answer to this question...
I have Ikea bulbs connected to my HC3, some directly via native zigbee and some via Hue - Though I'm not using Hue plugin as I am using the Skaro Automation bridge.  Functionally both ways work fine for me in terms of scenes and manual behaviour. I think from memory power outage is an issue for the natively connected. I can't comment on the Sonoff / Tasmota bridge or Ikea gateway as I haven't tried these........ but taking a quick look, I can't see a plugin for either, so I would say no
