Bart-Jan 0
I have a Double Switch 2 (FGS-223) and try to add the device to my Home Center 3. When select "Add Device" - "Zwave" - "Start" and push the B button 3 times to set it in learning mode (did it slow, fast and all possible options" it wil not find the device (not 1 minute not in 30 minutes). Did try another FSG-223, same issue (countdown goes to 0 and keeps circling around). Stang thing is dat I'm able to remove de device in the same way "Remove Device" - "Zwave" - "Start" does work actual. But afther try-ing to add it again, some issue, no device found. Device doesn't show up in de device list either. Followed all the instructions from the instruction manuals, several times (100 times) nothing is working.
11 answers to this question
