JeroenL 9
My aim was to clean up some of the scene's I have and group 3 motion sensor scene's, echt triggering a dedicated light. into a single scene using LUA.
In the below example the triggering to turn lights on by one of the three motion sensors works fine.
However, the timeout function, which should kick-in 2 min later, only works for the last device turned on.
As an example, I want to use this sequence of events in my staircase, walking up the stairs:
- Motion triggered on ground floor --> Light goes on [this works]
- Motion triggered on first floor --> Light goes on [this work]
- Motion triggered on second floor --> Light goes on [this works
2 min later, light on ground floor should turn off [this does NOT work]
2 min later, light on first floor should turn off [this does NOT work]
2 min later, light on second floor should turn of [this works]
I tried 2 different ways of programming this, one option is commented out, but it gives exactly the same results as described above.
It appears that the hub.setTimeout function only works on the last device switched on by the scene, if the scene get's activated again, previous " TimeOuts" appear to be forgotten.
Any suggestions? [Making 3 scenes works, but I wanted to move away from that, to clean up the super large number of scenes that are needed otherwise].
Thanks all.
4 answers to this question
