Neo Andersson 232
Guys anyone can assist me, cause i am probably missing something evident..
I am using a simple formula , where this timer start when my Rain sensor detects rain, so it waits 3 sec and then prints the message
later in the code i am testing the timer, and if exists i want to clear it
However this always throws me this error
[19.01.2023] [03:23:22] [ERROR] [QUICKAPP51]: in Event({"type":"device","id":57,"property":"value"}) => ..: ./include/eventDefinitions.lua:113: Wrong parameter type, number required. Provided param '[Timer:31866 02:31:47 01/19/23]' is type of table
So this indicates that rainref is a table when i assign it to seTimeout, on the other hand Cleartimeout functions awaits number...
Then i open a completely new QA, just for testint this functionality..i am following the same procedure...and in the other QA the rainref is a number, so the Cleartimeout can work...
What the hell is going on???
Anyone any clue???
This is my simple testing QA, and in this the timer references are always numbers and not tables..
10 answers to this question
