error on rule 297 Toon Energy app HC3
I always get an error from lua script on this app. :
[25.01.2023] [18:27:00] [ERROR] [QUICKAPP126]: QuickApp crashed
[25.01.2023] [18:27:00] [ERROR] [QUICKAPP126]: main.lua:297: attempt to index a nil value (field 'dev_2.4')
[25.01.2023] [18:28:00] [ERROR] [QUICKAPP126]: QuickApp crashed
[25.01.2023] [18:28:00] [ERROR] [QUICKAPP126]: main.lua:297: attempt to index a nil value (field 'dev_2.4')
I have Toon 2 rooted and firewall flushed. Fibaro HC3
I can communicate with it. I have another app Toon Connect 3.1 that is working without problems.
Am i doing something wrong ?
Regards
Anton
Edited by Anton Palm
13 answers to this question
Hi Anton,
you can set the quickapp variable debugLevel to 3 to get some more info on what is going on.
Edited by SmartHomeEddy
@Anton Palm
Lets mention @SmartHomeEddy he is the creator of Toon energy.
In the meanwhile, can you post the output of the following link.
http://192.168.1.50/hdrv_zwave?action=getDevices.json
Replace the IP with the Toon IP.
Eddy the ninja :)
    Hi Peter
    This is the response of the link you send:
    [25.01.2023] [19:02:00] [ERROR] [QUICKAPP126]: QuickApp crashed
    [25.01.2023] [19:02:00] [ERROR] [QUICKAPP126]: main.lua:297: attempt to index a nil value (field 'dev_2.4')
    [25.01.2023] [19:03:00] [ERROR] [QUICKAPP126]: QuickApp crashed
    [25.01.2023] [19:03:00] [ERROR] [QUICKAPP126]: main.lua:297: attempt to index a nil value (field 'dev_2.4')
    [25.01.2023] [19:03:20] [ERROR] [QUICKAPP126]: QuickApp crashed
    [25.01.2023] [19:03:20] [ERROR] [QUICKAPP126]: main.lua:297: attempt to index a nil value (field 'dev_2.4')
    [25.01.2023] [19:04:00] [ERROR] [QUICKAPP126]: QuickApp crashed
    [25.01.2023] [19:04:00] [ERROR] [QUICKAPP126]: main.lua:297: attempt to index a nil value (field 'dev_2.4')
    i put the response in a text doc
    here is the response as a text (zipfile)
    12 minutes ago, Anton Palm said:
    Hi Peter
    Oke. I compared it with mine, and it looks al your device ID's are +1.
    So where mine is Dev_2.4, yours is Dev_3.4 and so on.
    Not sure what is happening here :)
    me neither. a friend also has the HC3 , same app and toon2 connected. no problems. I dont know whats going on. Maybe my toon has newer version. I really dont know.
    The last value output for the Json is "currentwaterflow" did you install the app "Toon_water" or something like that.
    I dont have that in my output. Maybe it assigns the ID's different then.
    Maybe you have different firmware.
    You could change the code a bit. From that line 297 you could replace all 2. with 3.
    I just enabled mine Toon Energy (latest version from SmartHomeEddy) 2 days ago on a HC3 with a Toon 2, and it works fine for now. I don't have the currentwaterflow attribute as well (and no Toon Water installed/enabled).
    Edited by rliessum
    • Thanks 2
    I am on 5.49.4
    No updates pending.
    yes toon water is on it. I gonna change the 2 to 3 and lets see, i let you know.
    Yes this worked from rule 297 to 317 just make 2.1 and so to 3.1, that works. thanks for the help !
    Great 👍
    Please make a note or something, in case a next version of the quickapp comes available and overwrites your changes.
    Great!!
    Yes i will do. It was bothering me for weeks now. Really appriciate your help. Thank you many times.
