Built in HC3 integration with Nice products
i tried to use built in integration with Nice products (both pairing directly with gate and pairing using controller). Later was complete disaster, I had some success while pairing directly with gate, but I expected much more.
BiDi was total failure - ah ok, maybe my gate controller does not support BiDi, so I tried one-directional.
It paired the gate but it reacts very strangely. Eg. open/close buttons do not work, but step/by/step button acts as a "toggle state". Contrary at other gate step/by/step does nothing, but "open partially" acts as "toggle".
I tried to connect gate, sliding gate and garage door and all act differently.
Is it possible somehow customize registered Nice devices to at least set controls to use same comand buttons? Has anyone more experience with these? Fibaro? Anyone?
Thank you
M.
It means that gate was paired in Mode 2 (not automatic mode 1) with the remote.
Due that OXI module does not allow using actions which were not bound as start.
    Thank you. By "with the remote" you mean virtual fibaro remote or physical remote (I paired the gate that does this directly on gate controller).
    Is there anything that I can do differently for Fibaro integration to work correctly?
    M.
