Rikbast 3
I am trying this HTTP request in HC3 which always returns this statement:
{"error":{"message":"Cast to number failed for value \"NaN\" at path \"__QueryCasting__\" for model \"Ozone1\"","name":"CastError","stringValue":"\"NaN\"","kind":"number","value":"NaN","path":"__QueryCasting__"}}
I also get an 500 error code with this call
This request works flawlessly in HC2, so I am bit lost here. I adapted the HC2 code (hub.debug command only).
Might this be a bug in HC3? I just don't know what's wrong here.
This script has some more code, but that's just handling and data for input of the HTTP request (like token variable). I only copied the HTTP request here.
url:
local http = net.HTTPClient({timeout=20000})
function httpGetJson(url, body, func)
http:request(url, {
options = {
method = 'GET',
headers = {
['x-access-token'] = token
success = function(response)
print(response.data)
hub.debug("Scene6 API response",response.data)
hub.debug("Scene6",response.status)
local isOk, dataTable = pcall(json.decode,response.data)
if (isOk == false) then
func(false, "getResponseData ERROR: Invalid JSON: " .. dataTable ..
"\nWeb Server Data: ".. tostring(response.data))
else
if type(dataTable)=="table" then
func(true, dataTable)
else
func(false, "Data returned by json.decode is not a table")
end,
error = function(err)
func(false, "HTTPClient error: ".. err)
Any help is appreciated.
thx,
Rik
