Friso 0
Hello everyone,
I've been running my HC3 for a couple of months now. Main target was replacing my old alarm system and until now I've succeeded quite well. I'm running a Philio keypad to run Away, Night and Home scenes & profiles.
I'm using a simple script to change the configuration of the keypad when the alarm is armed / disarmed:
fibaro.call(DeviceID, "setConfiguration",1,1,1) for Entry Control Mode - meaning the user has to enter PIN and "unlock" button to disarm the alarm. LED color should be Blue.
fibaro.call(DeviceID, "setConfiguration",1,1,2) for Central Scene Mode - meaning the user can enter the "lock" and "9" buttons to arm the alarm for Away and Night profiles respectively. LED color should now be Green.
Since upgrading to firmware 5.140.17 the scenes running this, still work. However, strangely enough the keypad LED color doesn't change from blue (central scene mode) to green (entry control mode) and the other way around when the scenes are run.
Any ideas?
Thanks in advance!
