knuth 28
I have two FGWP-102 (FW version 3.2) which have worked normally for some years. During the last weeks, they both have malfunctioned in a strange way, first one then the other. The first observation was that they did not respond to remote controls, neither from the HC2 UI nor from scenes. The plug could still be operated using the button on the plug. The UI indicated "communication problem", which could not be corrected by clicking the icon to re-establish connection. It seems that the plug lost all connections to the z-wave network. The HC2 runs SW version 4.630.
The firmware version of the plug is confirmed as the last version. Several attempts to "soft reconfigure" all failed, with a message displaying a strange device ID. See attached screen dump, where the plug has device id = 324 (the master unit is 323), while the error message shows reconfiguration failure for "id 4097". There is no such id in use in my system. Full reconfiguration also fails. Trying to change some parameter to a different value and storing it did not kick-start the unit.
When this happened on the first plug, I was able to correct it by excluding the device from the system (forced exclusion), factory resetting the plug, and then re-install it. This, of course, gives it a new device id, and changes had to be made to all scenes where this device is used, but the "new" plug functions normally. This shows that the problem is not with the hardware. I have two questions:
Any ideas?
4 answers to this question
