thiagomuniz4404 0
Hey guys,
I install Fibaro equipment in automation switchboards, the idea came to me to monitor the temperature of the components, because the switchboards are closed inside a customer's structure (with ventilation)
How can I validate the temperature of each double switch connected to the HCL and HC3?
The idea is to have an alert if the temperature reaches the peak of the equipment's work, avoiding the possibility of fire.
Thank you all.
