Download & Filter HC3 History Data
l-i-n-k
I tried multiple ways to work with the history data provided in the HC3 portal with no practical way…
The API can export a JSON or XML from a device - but the complexity of the data makes it hard to use for a normal user!
Any LUA scripts to print thousands of lines is unusable (the device creates a record each 6 minutes resulting in 7200 entries for one month)
While the history page exactly shows me the desired data in the desired format - but no export as a CSV or any othe TXT file 🤯
I don’t understand why there is no "simple" button to save the displayed history data 🤔😒
7 answers to this question
    The data already exists in HC, but I just want to transform the data into something I can analyze. It seems a complete overkill to write a QuickApp to export (and increasing the load of the Homecenter). The suggested database server is of no help without coding as well… and I don’t need storage at all. I want to find out the solar energy production at certain hours of the day to get the proper level to use in a scene.
    Update from yesterday's research:
    Starting point is the JSON from the HC API
    http://xxx.xxx.x.xxx/api/events/history?objectType=device&numberOfRecords=7200&objectId=###
    xxx.xxx.x.xxx = IP adress of HC3
    ### = device ID to read
    Next step: Head over to Gigasheet and transform the JSON to a table including the columns you need:
    Good to know: The app can convert the number of timestamp entries in readable date and time!
    Export to CSV
    Import to Numbers or Excel and Filter to your needs.
    Yeah 🕵️‍♂️
    Edited by l-i-n-k
    This amount of data is probably more suitable for a external database like InfluxDB and the QuickApp to export the data.
    It is indeed overkill to write a QuickApp to export the data. Someone else already wrote the QuickApp to do so. 😀
    (Btw The data on your HC3 will not always be there, you will lose it at some point, for example after a firmware update and cleanup of logs)
    isnt it possible to export .csv from the general tab?
    Both on energy and temperature if it is that what you are looking for?
    /monthly_2023_05/image.png.a7da1ad668fa36004575addfa8dec520.png" />
  • @Brors94 As the label says: Only devices of temperature or energy type are exported. Lux (Light sensors) or my solar energy meter aren’t included.
    Because of this: No, unfortunately this export does not work.
    @SmartHomeEddy Appreciate your SolarEdge Monitor 🤩
    Currently, the API works just fine. With the
    , I can have the filtered CSV of a device within minutes. I would rather investigate in connecting the API to e.g. Gigasheet instead.
  • Just realized that you can get nice and easy api access with the Swagger interface. This allows you to play withe parameters.
    Hi all,
    My question is related to, but not exactly connecting to the topic.
    Is there a way, for example, to write out all the history on a daily basis to an excell or something?
    Not just energy and temperature. My client would like to have all user activity logged and stored.
    I am not great on coding, but this is one of the key requirement of the project. ( about 135 devices and 15 users with different rights would be involved...)
    Thank you in advance
