FGD-212 and motion sensor.
I'd like to use a FGD-212 to control a light into a corridor. I'll use a rule (send by my Eedomux box) to set the FGD-212 at 100% during the day and 20% during the night.
I want to start the light by connecting to the FGD-212 a motion sensor. I'm thinking of using two Legrand Ecodetecteur 078458 (2 wires sensor) which are already located at both side of the corridor.
Is it possible to connect a motion sensor to a FGD-212 (as a toggle swich) ?
As the motion sensor need to be connected all the time to the electric source, does the FGD-212 provide some power to the motion sensor at any time ?
I'm giving here some drawing of the connections.
Thank you for the help
6 answers to this question
@Chris59
Hello.
Short answer: It is not possible to combine it like this!!!
Long answer: Connect the relay winding to the sensors instead of the light bulb. Then switch inputs S1 and S2 on the FGD-212 module with the relay contact.
Pay attention to the minimum load on Legrand sensors 0.02A (or 3W according to the manual). Functionality must be verified.
Good advice over gold: Use a detector with a relay output instead of a semiconductor element. Sometimes they have a voltage output, but they only switch the phase with an internal relay.
eM.
    Good afternoon Martin,
    Thank you for your advice, as I'm not a specialist, can you give me a small drawing, even draw by hand 🙂, because I'm a little bit confuse by the relay connection.
    Thanks a lot
    @Chris59
    I assume you wanted to control the same thing from both places.
    This is what the picture is drawn for.
    If you wanted to use switch S1 to turn the light on and S2 to turn it off (with a connection to different sensors??), you would have to separate the sensors and add a relay to the second sensor as well.
    You're trying to fit one two-wire system to another and it just won't work. Try it with a relay and see. If you have already purchased items, this will be the smallest item.
    Edited by Martin_N
    Good morning Martin and thank you for the drawing
    This is already an old topic, but is there anyone who could tell me what kind of relay I have to buy for this solution?
    And what is the function of de Sx-port on the FGD-212?
    Kind regards, Peter
    Edited by Peter van Heesewijk
    @Peter van Heesewijk
    Hello.
    This whole case is a very unusual connection and requirement. Do you really have this configuration of connections and devices?
    For example, the FINDER 40.61.8.230 relay will do
    Don't forget to buy a socket if you don't want to solder the wires directly to the legs.
    Sx - terminal for power supply to the switch connected to the
    Dimmer... as in the manual!
    Don't forget that you are working with dangerous voltage, follow all regulations and be careful.
    If you don't know what you are doing, call a professional. It's about property or even life.
    eM.
