Robin_Hood753 0
Introduction
I am creating a scene to open my window blinders in the morning to a position where they still block the sun, but light comes into my house. I have 4 blinders in my home with each their own Roller Shutter 3 that is connected to the HC3. All the roller shutters are calibrated with their respective blinders.
Problem
In the morning when I woke up, I noticed the scene had been running, but only 1 out of 4 blinders was in the correct position. When I manually run the scene again, all blinders are going to the correct position. Then I started to investigate further and I noticed the following:
Only 1 out of 4 blinders I can set the position to a specific value directly from closing position, the other 3 I cannot. I also tried setting the level via the HC3 manually by going to "Settings" => "Devices" => "The blinder" => "Preview" => Set the level there. This gave the result that he will show that the blinders will go to 50%, then the blinders will open, but they fully open and then the level changes automatically to 99%.
I checked that all the parameters of the devices are the same, and they are. Which leave me without a clue what to try next.
