can't log in with local user.
Hello. So I just upgraded from HC2 to HC3 and I try to figure all the new stuff.
I have created some users that don't have an Fibaro ID (like my admin account does). The reason is that I want them to just be able to log in when they are locally present.
But when I try to set up the Yubi app, I can't get it to work. it says that I should connect to my gateway, I don't know where to get the QR code so I hit the option MANUALLY
Then I get this screen that says that I should choose my gateway, But Im allready on my wifi. The same wifi that I enabled on my HC3 (that is also connected to my LAN)
So I point to "I'm already connected" That takes me to this screen.
As i can see on your screenshots, It asks you to connect your mobile to Gateway's wifi  not to your home wifi (to finish the setup). This is just my tip. So go to your phone Wifi settings and select the temproary WIFI network that has been created by your Gateway.
Just a tip.
Edited by Neo Andersson
