yves.guern 1
For your information here is a mail sent to Fibaro & AEOTEC
in summary: 2 Home Energy Meter Gen5 that were working (80%) on HC2 are unable to provide any information with HC3.
For sure I will let you know, but If you may help also it would be great...
Hi
Here is a description of my problems:
(foreword: I have a three phases installation)
I had for years, 2 “Home Energy Meter Gen5” included in a Fibaro Home center 2 without problems.
After inclusion in HC2 I get 12 ‘fields’ = 4 x 3 [total of 3 phases, phase 1, phase 2, phase 3] x [Wh,Amp&Voltages]
Even if “Watt” fields seems to be missing (I don’t need them), it has been working (fields updated) as waited.
Today I try (successfully) to remove those sensors from my Home Center 2 and then I include them in my brand-new Home Center 3.
Note, before answering, that I try inclusion in HC3 at least 3 times and a reset of “Home Energy Meter Gen5” (pressing button 10s) had been tried without any change.
After every inclusion in HC3 I get 32 ‘fields’ (!!!) = 4 x 8 that seem to be :
[total of 3 phases, phase 1, phase 2, phase 3]x [Wh,W,Amp,Voltages, Wh,W,Amp,Voltages]
ie twice the number of waited fields.
And even Worse, None are updated on real changes (even if my pool’ pump is switched on/off (1kW))
RK: On the HC3 interface, when the HC3 is rebooted, the classic message ‘transfert OK’ is seen with every fields. But this happens only once, and values are not coherent. I mean that ‘volts’ values are “realist” but Amps and Watts are not real (V x A != W) and Total of phases fields are not the sum of whatever is in the other fields .
End of the day I had to reinclude these sensors in my HC2 but I really would like to take away my HC2 from my installation.
Today it seems impossible, your help will really be appreciated.
Best Regards
Yves Guern
PS: This request is send to Aeotec, Fibaro (& fibaro forums)
My HC3 is running SW version 5.130
AEON is V 1.5 (as per what is seen on HC2 interface)
14 answers to this question
