How connect Satel B1 magnetic contact to the UBS
I am trying to connect UBS to magnetic contact Satel B1. I have connected Satel to input 1 and share neutral cable with magnetic contact, but ubs doesn’t see changes of state.
    I think issue is with UBS because when I Connect IN1 with GND should be some response from sensor in event log..
    Check the pooling from HC3 on the device (parameter on the main UBS card). Set fixed pooling.
    Do you happen to have a disabled device?
    Try how IN2 behaves.
    You can try using the GND wire from the thermometer (on the other side of the connector).
    I bought Smart implant but I have the same issue. I can’t find parameter 20 for changing type of sensor
    I found works :) now everything works
    Congratulations...it's been a thorny road..
    So defective UBS?
