Neo Andersson 232
Hello Jan, i am moving the discussion here..
In a rule like this
i can understand, that 'once' statement is good for cases like this..when ext_lux_sensor value drops under 720, we don't want the action to be triggered every time, this is clear to me. But we don't want to use this lux checking part as a trigger!!! That is the problem. I want it to be a condition and not a trigger. Thats why i asked how to use it.
So i don't want the light to be turned on at all whatever the ext_lux_sensor value is, i just want it to be controlled in case of office_sensor is breached. So how to do that? How to make a condition (NOT a trigger). I checked the logs you mentioned, and it says
, meaning that the lux sensor changing will be used as trigger also.
And if using the 'once' statement, should i use it for the entire left part of the rule e,g,.
or just for the sensor part e.g.
9 answers to this question
