Heat controllers, Relay and Heatit Thermostat
I have following setup:
Fibaro heat controllers in every room (some rooms still have Danfoss Z-wave valves)
1 singel relay for the kettle: On/off
1 heatit thermostat to manually override the schedule; i.e somebody is at home early, sick or whatever.
All devices were integrated properly but don't seem to work together.
The relay doesn't turn on when I ask higher temp on the heatit thermostat.
Also, I reached 24 degrees, and the relay didn't turn off.
In HC2 you had to link the devices. In HC3 I don't see that option.
I followed this, but no succes:
Then I found on the forum that I had to add the thermostat as "other device" etc... no succes.
All help will be appreciated!
Thanks in advance!
Per room or area to be heated, you can define a zone in the settings -> climate panel.
In the upper right corner (pencil) you can define which sensor needs to be used for temperature and which devices are controlled.
You need to add a separate quick app to switch on the boiler when one of the zones requires heat.
That was also the case in HC2.
