[SOLVED]HC3 /app/settings/devices does not load
I have an HC3 with 5.140.17 running with several zwave as well and zigbee devices connected.
It is stable and everything runs as it should.
But since today, I cannot open /app/settings/devices anymore.
All other panels open without a problem, but the devices part simples does nothing.
There are also no errors visible in the Fibaro environment.
When I open the browser inpection page of Edge, I see some errors like:
Uncaught SyntaxError: Invalid or unexpected token (at
ERROR Error: Uncaught (in promise): ChunkLoadError: Loading chunk 1507 failed.
I don't know whether this is a normal error or not. With other pages, I do not see this error.
I already rebooted the system, cleared the cache of the browser and used another browser, but it simple won't load anymore.
Does anyone have an idea what the problem can be?
Thanks, Willem-Jan
Hi @Willem-Jan
Did you try to use the other interface, so WiFi IP HC3 address instead of Ethernet (or the other way around)?
Worth a try.
 try incognito tab, we see that sometimes edge ignore no cache attribute
    Yep, that does the trick. Thanks!
    Strange this as I got the same problem on Chrome.
    Anyway, it is solved.
