Walli Roller shutter Scene control not working
Hi all,
I am in the process of migration from HC2 to HC3, unfortunatelyhave to setup every device again.
Here I have a problem with the Walli Roller shutter, which I have configured to close all shutters on double click.
What I did:
Set Parameter 40 and 41 to activate on double click.
Set scene to close the roller shutters on double keypress for key 2. When I double click on the wall nothing happens no logs nothing.
What am I missing?
Cheers
joystick
    ok, so I found it myself.
    1)you need to set the scene to "Auto" start
    2) There are two ways to use the switch in a scene a) Remote b) device. Only device works correctly.
    cheers
