Sankotronic 2,375
Hi dear all,
I have several door/window sensors FGDW-001 of version 2.5 that seems to start dying.
Even with inserted new EVE battery they are reported dead "no-communication" if not opened/closed between two wake up events. When they are marked as dead and then opened/closed then they become LIVE again and show proper status of the window/door, but die again if there is no change of state for the duration of the wake up time.
Have also, few that are occasionally reported dead, but then after some time they became live again even status open/close was not changed.
Is there anyone to have similar behavior of this old type of the DW sensors?
Actually is there anyone that still have this old type in use?
I like these old ones because it was possible to connect temperature sensor DS18B20 on the wire so for example have machinery room door status and also temperature of the swimming pool water. Now I have to replace it with smart implant which requires power supply too, so pulling some wires, installing IP44 box etc.
6 answers to this question
