Neo Andersson 232
Guys, in my other topic i have shared a QA that can be used even for automatic backup management. (i am gonna share it here too)
As i have mentioned in the descritption, i had no possibility to test it on multi gateway systems.
I have gotten some feedbacks that in systems with slave gateways it fails, so i was about to find the reason, however i could not come up with any solution.
I am strongly inlicned to a reason, that is coming from Fibaro itself. More convinced i became, when on some customer's systems where slave gateways were present, the simple upgrade (started from Fibaro web) failed.
It showed a error message, that backup creating failed on connected gateways, so i am pretty convinced that this is a Fibaro bug.
I don't know, if anyone has any clue about this, but some contribution to check the QA on more systems would be nice.
I am sharing it here in unencrypted format, as some of you requested. I had no issues at all on simple gateway systems so far.
