Ronald H 1
Hi All
I am using HC3 as the central control for an alarm system, part of which will turn on mains powered security lights when an intrusion occurs.
If the mains power fails the HC3 and all battery operated sensors will continue to operate, but Z-Wave switches controlling those security lights will not operate.
This creates a problem for HC3 tasks following those failed switches because the operation loop stalls for quite some time.
Is there a way that HC3 can detect a mains failed switch, pass through it and continue with the next task in the loop with no appreciable delay. Currently about 40 seconds depending on type of failed switch
Regards Ron H.
