Export temperature chart data
Guys, anyone know how can i export temperature sensor's data from chart?
I need to get a longer period (a month maybe) with all values and times measured by the sensor.
Thanks in advance
Thanks in advance
That's different...
Btw, I edited the post, you should addd hour=0
    22 minutes ago, jgab said:
    That's different...
    Can you show me the way i get binary switch events?
    Please
    Edited by Neo Andersson
    @jgabJust what I need!
    I added your rules in ER5 QA
    Can I do multiple devices?
    How I can print now to test how it looks like?
    Can the date be exported to email?
    Edited by Sjakie
    No, you need to call it for each device.
    Well, printData(data) will print it to the console.
    To email, in theory yes, are there any length limits?
    Wow great!
    Is it possible to have the "RoomName". "DeviceID before the date?
    Lengt limits? As in email I don't know but will see if it's coming true yes or no. If there is a limit I can choose one week instead of a month?
    @jgab Jan this is a mega help for me but i have found some unexpected results.
    Please check this..How is this possible. I m checking device 316 events. This is in history from Fibaro UI
    The export function did not find any entry for this device. Not only for this particular date, but at all.
    How is it possible?
    I have tried to manually turn off an on th device, than the on off event shows up, but only this one from todays test, nothing from the past.
    Did you add the hour=0 in
    Secondly, what kind of device is it?
    Yes, there is the hour argumen, i am using the sheer copy of your last post.
    It is a binary switch
    1 hour ago, Sjakie said:
    Wow great!
    This sends the temps for the last week every Sunday
    I'm a bit unsure if you get html codes in the message - let me know...
    Is save events to history enabled for the device?
    /monthly_2024_01/image.png.be07741efe5ac59f52fd63515376b7dd.png" />
    Yes, it should be. you show me the history...
    What does it say if you log the raw data from the api
    It's kind of a bug, it doesn't include the last day so last day should be set to +1 day, because it starts and end at 00:00 the days specified
    Sorry i cant format to JSON here
    /monthly_2024_01/image.png.90cba36f8370ce2665431f16dbdfa46b.png" />
    If I replace your data as the response to the api call
    I get
    I get
    Yes me too
    The 18 jan event is my test. I just turned OFf and ON the device to see if it shows up..It shows up but nothing from the past
    1 minute ago, Neo Andersson said:
    Yes me too
    Maybe it is som bug in Fibaro? Becuase if i roll over the history tab in web UI i can find entrys for this device. As you can see on my screenshot.
    18 minutes ago, Neo Andersson said:
    Yes me too
    Ok, but if you log data from ex. "2024-01-01" to "2024-01-17", what json data do you get then?
    I got nill
    I got nill
    I got empty data table
    I have changed to log function to show me if data is empty
    and i got no data at all message
    7 minutes ago, Neo Andersson said:
    I got nill
    I got nill
    Yes, because there are only property 'energy' and 'power' in that period. No property 'value'
    So history is saved but not property 'value' (e.g. on/off)
    I dont get it. How is it possible? You can see that i can see in Fibaros histry panel the enrtry for turnOn action
