HC3 Adding Elero 868 shutters with Fibaro 28 400 .0001 controllers
I have 10 Elero shutters Previously controlled by Vaiotell2 and Fibaro 28 400.001 trying to add them to HC3 but does not recognise via add new Elero device.
Any advice please
5 answers to this question
@Doug Ellott The compatibility list is
    Thank you listed as compatible but doesn't work.
    So you have 10 shutters and for each shutter you have one Elero Revio-868 (284000001).
    And each of these revio is bound to one channel in the variotel? (Do you have multiple variotel?)
    Is that correct?
    You have to start the binding of each motor so that you can bind it to YH/HC3.
    You can start binding of a motor from the variotel with pressing UP+DOWN+LEARN(P) for at least 3seconds.
    After starting the binding you can add it with elero device inside the YH/HC3.
    I just cross checked and if I am correct the 284000001 version of the Revio-868 is the uni-/monodirectional version (old version) of the device.
    Therefore this version isn't supported by the HC3/YH because only bidirectional versions are supported (284000006).
    You can check if the revio is undirectional: Press any button (UP, STOP or DOWN) on your variotel. If the led is green every time the revio is uni.
    Thank you Stycx. The light is green every time so presume uni
    I have 2 5 channel variotel transmitters each paired to a revio 868 shutter controller
    Will continue with any suggestions offered
