HenryEST 0
Hi!
A year ago i went from HC2 to HC3. I used manual method and excluded all devices from one and started to add them to HC3. Everything exept 3 door/window sensor. So i leaved them at this time. Now i found them again, put new batterys in and started to include them... i cant include them with 3x tmp click... but i can include them with 5x tmp click. Okey, they show up in my HC3 but
one sensor with FW 2.1 shows like all okay, but it wont respond to magnet.
second one same thing 3x tmp click won't do nothing. 5x tmp click add's it ti HC3 but it shows that battery is 0%. I know for a fact that it's not true and battery is new. But it works like a door/window sensor, reacts to magnet and all. Firmware version 2.5
the third one... firmware 2.5... same thing... it won't do nothing with 3clicks but works with 5 clicks. Battery shows 100%... it works but as soon i change "door sensor" to "windows sensor" it stops working and shows battery 0%
all three drains batterys in matter of hours... after 4-6hour they are half empty, after one day they are depleted
i also tyd them to home assistant... result is the same. So problem is not in HC3 but in sensors.
Also problem with fibaro dimmer FW 1.9 (Dimmer 1?) I have lamp with 6 bulbs. Bulbs are Ledvance dimmable e14. They worked fine previously, but now... they blinking... and not all of them in same time but in different times. but all of them are connected to ome dimmer and one wire (they are not separatly switchable)
11 answers to this question
