    Ok, the parse error could actually have been a problem that caused 429 in other scenarios too.
    I uploaded v 0.2.66 with some fixes I hope will improve it - including allowing for better performance.
    Jan, after update v02.66 I have only warnings, so Yahue works great!
    Can I perhaps solve a few warnings?
    The "Missing resource type:xxx" is no problem, just a reminder that these Hue resources are not supported.
    The "Variable sseHeartbeat not found", I have made silent.
    "Class does not have 15 function defined - action ignored" is very strange. I made some changes in the last version, please report if you still get the warning-
    After update and extra restart:
    The restart was unexpected, try version v0.2.68 I just uploaded.
    vo.2.68
    22 minutes ago, Sjakie said:
    vo.2.68
    Yes, that's better. The missing resource warnings will be there.
    Thank you very much! I will try v0.2.68 today and let you know.
    @jgab First test: works. I'll test it this evening, maybe the Hue motion sensor gives off different events or data, I don't know.
    During daylight I see no errors in the console and the Controller click successfully controls the Hue light via YahueV2, even after having passed the motion sensor multiple times.
    Thanks for the QuickApp - it works perfectly with the HUE lamps.
    With the NEUHAUS lamps I can switch them on and off, but I cannot change the light warmth (color temperature). Is this adjustment planned?
    That would be great.
    Thanks!
    Edited by Flexo
    Solved.
    On 6/3/2026 at 4:36 PM, jgab said:
    Not released yet, but work in progress + questions
    Item 4: Capabilities
    Stored in quickAppVariable 'capabilities'
    Item 5: Scene stepping
    Added to RoomZoneQA (inherited by RoomZoneDimQA, RoomZoneSwitchQA):
    - `nextScene()` — cycles forward through the room's scenes (wraps around)
    - `prevScene()` — cycles backward through the room's scenes (wraps around)
    Usage from another QA or scene:
    fibaro.call(roomChildId, "nextScene")
    fibaro.call(roomChildId, "prevScene")
    The scene list is populated at startup in loadScenesForRoom and stored as self._sceneList. The current scene is tracked via the existing lastSceneId variable. Honors the sceneMode setting (static/dynamic).
    Items 1, 2, 3 — Questions
    Item 1 — Step dimming API
    Does not exist. The Hue v2 API natively supports dimming_delta with action: "up"/"down" and brightness_delta (percentage of full range), which would be the most reliable mechanism — the bridge handles the ramp internally and it's compatible with existing stopLevelChange.
    Question: Preferred API shape?
    - fibaro.call(id, "stepValue", 5) / fibaro.call(id, "stepValue", -5) (Fibaro style)
    - fibaro.call(id, "dimStep", "up", 5) / fibaro.call(id, "dimStep", "down", 5) (explicit)
    Item 2 — Robust stopLevelChange
    Already implemented. Both DimmableLight (line 789) and RoomZoneQA (line 1270) send dimming_delta={action='stop'} via the bridge's native stop command — the most reliable mechanism available at the API level.
    Question: Have you observed specific stop failures? Under what conditions (fast ramp, specific light models, combined with other commands)?
    Item 3 — Configurable dimming parameters
    Partially exists. dimdelay (default 8000ms) and transition (default 0) are already configurable per-child via QuickApp variables. dimstep and diminterval are new and would be relevant for step dimming.
    Question: Is diminterval needed for Yahue to handle internal repeat timing, or does the Matrix keypad/controller handle hold-repeat timing itself? (Typically the controller determines repeat rate — Yahue just needs to respond to each individual call.)
    Hi Jan,
    Thank you for the detailed update.
    For the step-dimming API, I would prefer the Fibaro-style approach:
    `fibaro.call(id, "stepValue", 5)`
    `fibaro.call(id, "stepValue", -5)`
    The keypad/controller should handle hold-repeat timing, so I do not think Yahue needs an internal `diminterval` repeat function.
    Regarding stopLevelChange, I have not identified a specific failure pattern. My main focus is ensuring reliable interoperability between EV7 and Yahue, so EV7’s level-change and stop behaviour maps cleanly to Hue’s native dimming_delta commands.
    The capabilities variable and the scene-stepping additions also look good.
    My immediate focus has unfortunately shifted. My HC3 entered recovery mode twice, and I spent nearly two weeks with Fibaro Support trying to identify the cause and prevent it from happening again. I have now given up on that support process and decided to start over instead.
    Fortunately, I had saved a substantial part of my rules on my Mac, so migrating the logic to EV7 should be much easier.
    Best regards,
    Christian
    But isn't stepValue the same as
