    Ok, the parse error could actually have been a problem that caused 429 in other scenarios too.
    I uploaded v 0.2.66 with some fixes I hope will improve it - including allowing for better performance.
    Jan, after update v02.66 I have only warnings, so Yahue works great!
    Can I perhaps solve a few warnings?
    The "Missing resource type:xxx" is no problem, just a reminder that these Hue resources are not supported.
    The "Variable sseHeartbeat not found", I have made silent.
    "Class does not have 15 function defined - action ignored" is very strange. I made some changes in the last version, please report if you still get the warning-
    After update and extra restart:
    The restart was unexpected, try version v0.2.68 I just uploaded.
    vo.2.68
    22 minutes ago, Sjakie said:
    vo.2.68
    Yes, that's better. The missing resource warnings will be there.
    Thank you very much! I will try v0.2.68 today and let you know.
    @jgab First test: works. I'll test it this evening, maybe the Hue motion sensor gives off different events or data, I don't know.
    During daylight I see no errors in the console and the Controller click successfully controls the Hue light via YahueV2, even after having passed the motion sensor multiple times.
    Thanks for the QuickApp - it works perfectly with the HUE lamps.
    With the NEUHAUS lamps I can switch them on and off, but I cannot change the light warmth (color temperature). Is this adjustment planned?
    That would be great.
    Thanks!
    Edited by Flexo
    Solved.
    On 6/3/2026 at 4:36 PM, jgab said:
    Not released yet, but work in progress + questions
    Item 4: Capabilities
    Stored in quickAppVariable 'capabilities'
    Item 5: Scene stepping
    Added to RoomZoneQA (inherited by RoomZoneDimQA, RoomZoneSwitchQA):
    - `nextScene()` — cycles forward through the room's scenes (wraps around)
    - `prevScene()` — cycles backward through the room's scenes (wraps around)
    Usage from another QA or scene:
    fibaro.call(roomChildId, "nextScene")
    fibaro.call(roomChildId, "prevScene")
    The scene list is populated at startup in loadScenesForRoom and stored as self._sceneList. The current scene is tracked via the existing lastSceneId variable. Honors the sceneMode setting (static/dynamic).
    Items 1, 2, 3 — Questions
    Item 1 — Step dimming API
    Does not exist. The Hue v2 API natively supports dimming_delta with action: "up"/"down" and brightness_delta (percentage of full range), which would be the most reliable mechanism — the bridge handles the ramp internally and it's compatible with existing stopLevelChange.
    Question: Preferred API shape?
    - fibaro.call(id, "stepValue", 5) / fibaro.call(id, "stepValue", -5) (Fibaro style)
    - fibaro.call(id, "dimStep", "up", 5) / fibaro.call(id, "dimStep", "down", 5) (explicit)
    Item 2 — Robust stopLevelChange
    Already implemented. Both DimmableLight (line 789) and RoomZoneQA (line 1270) send dimming_delta={action='stop'} via the bridge's native stop command — the most reliable mechanism available at the API level.
    Question: Have you observed specific stop failures? Under what conditions (fast ramp, specific light models, combined with other commands)?
    Item 3 — Configurable dimming parameters
    Partially exists. dimdelay (default 8000ms) and transition (default 0) are already configurable per-child via QuickApp variables. dimstep and diminterval are new and would be relevant for step dimming.
    Question: Is diminterval needed for Yahue to handle internal repeat timing, or does the Matrix keypad/controller handle hold-repeat timing itself? (Typically the controller determines repeat rate — Yahue just needs to respond to each individual call.)
    Hi Jan,
    Thank you for the detailed update.
    For the step-dimming API, I would prefer the Fibaro-style approach:
    `fibaro.call(id, "stepValue", 5)`
    `fibaro.call(id, "stepValue", -5)`
    The keypad/controller should handle hold-repeat timing, so I do not think Yahue needs an internal `diminterval` repeat function.
    Regarding stopLevelChange, I have not identified a specific failure pattern. My main focus is ensuring reliable interoperability between EV7 and Yahue, so EV7’s level-change and stop behaviour maps cleanly to Hue’s native dimming_delta commands.
    The capabilities variable and the scene-stepping additions also look good.
    My immediate focus has unfortunately shifted. My HC3 entered recovery mode twice, and I spent nearly two weeks with Fibaro Support trying to identify the cause and prevent it from happening again. I have now given up on that support process and decided to start over instead.
    Fortunately, I had saved a substantial part of my rules on my Mac, so migrating the logic to EV7 should be much easier.
    Best regards,
    Christian
    But isn't stepValue the same as
    I'm running a Hue Dimmer Switch through Yahue v2 on HC3, and I'm seeing a reproducible issue: roughly every 30 minutes, during what looks like a periodic reconnect/resync cycle, button 4 fires a full Pressed → Released sequence even though nobody touched the switch. Buttons 1–3 do not show this behavior — they're correctly reset to idle.
    Example from my log (this pattern repeats every ~30 minutes, all day):
    Note that buttons 1, 2, and 3 all reset cleanly to _ _ during the resync, but button 4 gets an extra Pressed initial_press / Released pair about 1 second after its own _ _ reset. This exactly matches the last button I physically pressed on the dimmer (button 4, hours earlier) — so it looks like the resync logic is somehow re-emitting the last "active" button state as a fresh press instead of just resetting it to idle like the others.
    This causes real problems downstream: I have an HC3 scene bound to button 4 (hub.scene("execute", ...)) that gets triggered every 30 minutes by this phantom event, forcing my target scene to run repeatedly without any real button press.
    Is this a known issue? Happy to provide more logs or test a fix if useful.
    Thanks!
    Thanks!
    Thanks, I do believe I know what the problem is. Will have a look at it...
    I pushed v0.2.69.
    It has 2 main fixes.
    - buttons and sensors don't republish their events when the QA starts up (thanks @_Marian_)
    - a new logic to keep the event stream open. Sometimes the event stream opened to the Hue hub goes stale and it's hard/impossible to find out from the net.HTTPClient code.
    Now there is a quickAppVariable 'watchdog' that can be set to 'time' or 'poll'
    - 'time', means that we monitor the socket and if we don't get any event for x seconds we restart the QA and reconnects.
    - 'poll', means that if we haven't got any events for x seconds we poke the hub so it emits an event, if no event back we restart the QA:
    The time x is set by the quickAppVariable 'watchtime'.
    The default for 'watchdog' is 'time'
    The default for 'watchtime' is 1800 (30min) for time, and 60 for poll (1 min)
    The default is 'time' now to mimic the old behavior, but I would recommend people to try out poll as it is more effective and responsive if the stream goes stale.
    Hi jgab,
    thanks for the great work on YaHue v2! I wanted to update to the latest version, but I couldn't find the update QuickApp variable in my installation. I created it manually (name: update, value: yes) and saved it, but unfortunately nothing happened afterwards — no update was triggered.
    Thanks any suggestions-
    QA Dist Manager is the preferred way to upgrade/update Yahue
    bug in v0.2.69 when watchdog poll was selected. Fixed in v0.2.70
