When testing with exporting and importing (on another HC3) an encrypted QA the QA often crashes at start-up.
The code is not running at all. I can tell this because:
1. I change the QA name with _TAG and that name  is not used in the log;
2. The first line in my OnInit code is a self:debug("hello world") and that doesn't show up at all.
I tested this with encrypting on the latest 5.154 beta and importing on the same beta and the stable version.
I splitted my code in multiple "files". I don't know if that is the issue.
If you remove the QA and import again it works.
