BernhardGK 2
Hello
I am using several (it is 29) Walli Roller Shutters (GWREU-111).
Most of them work fine, but some of them seem to have incorrect power consumption indication. The one with this "bug" need adjustement in the parameter 155 (Limit Switch Power Threshold). Only if this parameter is adjusted, the mode "Venetian Blind with positioning" works (at least partially). In case I use the default value for parameter 155 (which is 10W), these blinds only move for about 1sec and then stop. After adjusting parameter 155 positioning works, but there remain some issues with the related devices: (a) self calibration does not work, (b) positioning of blinds sometimes works incorrectly and incorrect position is indicated and (c) setting the slats angle does not work correctly.
The devices that work fine are indicating a power consumption (while moving the blinds) of about 80W, while the ones that show the problem are only indicating 0,7W. I expect this is not a problem of my installation, all motors are the same and electric installation seems to be correct and identical for all of them.
Thanks for any support.
Bernhard
