Just a quick update I thought I would share to save members some time,
I have Danalock V3 and wanted to connect it to my new HC3 but couldn't do it, every time I do that, it will connect, but it will not control the lock, the buttons will sit there, and when you click Open or Close, nothing happens.
After several emails with Fibaro and Danalock support, the solution was to include it using S0 (in advanced inclusion menu) instead of the default S2, as S2 is causing problems as per the Danalock support. I did that and now it is working normally.
Cheers,
I confirm that this tecnique also worked for me.
Paolo b.
