uwuertz 1
QuickApp to read the EASTRON SDM630 V3 and SDM230 V2 Modbus Smart Meter for HC3
This QuickApp is for querying pretty much most of the parameters of the Eastron SDM630 / SDM 230 Modbus devices. It reads directly from the Modbus server, for example a Modbus Device Waveshare RS485 to RJ45 Ethernet Industrial Serial Server Modbus Gateway.
Some important information:
Variables:
Important: If ChildDevices are deleted using "enabled=false", the data stored for this ChildDevice up to that point is also deleted! If this is not desired, the device should be managed via the interface. I would not recommend reading all the parameters as the QuickApp has otherwise put too much load on the HC3 memory in my case.
Use at your own risk, I have written the device myself for my own purposes and the code can be used without any guarantee of completeness and correctness. If you don't want to take any risks, just leave it. Code is still subject to change.
Have fun!
Edited by uwuertzCorrections
