Hello,is there a way to integrate zigbee thermostats(Moes etc) or wifi thermostats (like Beok wifi) ?  Thank you
Zigbee needs to be tested to get the real answer. Teoretically it can work, as Fibaro has Zigbee support (still in Beta though, but to be honest i dont know how it will work with thermostats. Never tried.). Regarding the WIFI it depends on the brand. Does it provide any API support, and if so, are you able to create a QA plugin for the control. Or somebody can do it for you.
Edited by Neo Andersson
