Can’t Force Remove Device from Slave Gateway
I am trying to remove a device (Shelly Pro Wave 1PM) which I no longer have from a Slave Gateway and it fails to be removed.
The device when operated, even though it doesn’t exist, reacts as if it were still there and says ‘transfer ok’!
TIA
Edited by Merlin
2 hours ago, Merlin said:
I am trying to remove a device (Shelly Pro Wave 1PM)I no longer have from a Slave Gateway and it fails to be removed.
TIA
We had several similar situations..Most of the time de regular Remove used to work even after the device is not present in the System.
    Thanks for the reply. I have tried your suggestion, but still can’t get rid of the device.
    In this case, please contact support,they will solve it.
