This is a QA under development that imports IKEA Dirigera registered devices as HC3 devices.
Besides investing in the hub, the devices are pretty cheap... and having the hub we can have an efficient API and reliable support for the Ikea Zigbee devices :-)
Btw, it's a web socket api so no polling and quick updates...
Recommend to update/install with <
  1. Set the IP quickVar to the Dirigera IP address
  2. Press "Request token"
  3. Press the action button on the underside of the Dirigera hub
  4. Press "Get token"
  5. If successful, select device that should be mapped in the UI drop down list and restart the QA. The QuickAppChildren for the selected devices will be created.
There is still some stuff missing
  • Lack of device support for stuff I don't have, roller shutters, water alarm etc.
...If people have other devices or need different functionality, please feel free to improve on the code...
Tested with:
  • Smart plug INSPELNING (energy reporting not yet implemented) - implemented as com.fibaro.binarySwitch
  • Door/Window sensor PARASOLL - implemented as com.fibaro.doorSensor
  • Wireless motion sensor VALLHORN - implemented as com.fibaro.motionSensor and com.fibaro.lightSensor
  • LED strip ORMNAS - implemented as com.fibaro.colorController with R,G,B and warmWhite color component
  • TRADFRI bulb E27 WW globe 806lm - implemented as com.fibaro.multilevelSwitch
  • TRADFRI bulb G12 E27 WW opal 470 - implemented as com.fibaro.multilevelSwitch with custom temperature slider
  • Environment sensor VINDSTYRKA - implemented as com.fibaro.temperatureSensor and com.fibaro.humiditySensor (PM25 coming)
  • Simple play/stop/skip for registered Sonos compatible speakers, tested with IKEA Symphony
Untested, but may work:
  • Color lightbulbs (should behave like LED strip)
  • Water alarm BADRING
Besides devices, it also supports to trigger and "undo" Dirigera scenes
  • Like 8
  • Thanks 2
    v0.8 lots of bug fixes, better color light support
    @jgab
    I havent seen on the code, but is it a local api? 😄
    23 minutes ago, Brors94 said:
    @jgab
    Yes
    v0.9
    • better color light support.
    • water sensor may work...
    • Dirigera scenes can be triggered
    • Like 3
    v0.95
    • Better light support,
      • White bulbs with temperature is implemented as multilevelSwitch with custom slider for temperature. Current temperature is stored in quickApp variable
    • Offline/dead updated (hopefully) when power is cut
    Hi @jgab,
    Today I bought a Dirigera hub and a Tradfri driver.
    I think there is an error in the QA somewhere, I can get the token but I get an error when creating the child devices:
    [18.10.2024] [17:17:24] [ERROR] [QUICKAPP938]: createMissingChildren:./quickApp.lua:416: attempt to index a nil value (local 'child')
    I downloaded v0.95
    P.s. I am on the latest beta.
    Jimicr
    1 hour ago, jimicr said:
    Hi @jgab,
    I downloaded v0.95
    Jimicr
    Yes, you are right. something strange has happened with the code...
    Will try to fix it as soon as possible (a bit busy tomorrow unfortunately)
    Thanks, take your time :)
    v0.96 - fix bug introduced in instantiating children of type dimmable light.... thanks @jimicr
    Goodmorning @jgab,
    Thanks for your fast action.
    I sadly must report something else broke, this is the debug after pressing "request token":
    [19.10.2024] [08:53:13] [DEBUG] [QUICKAPP940]: Dirigera version: 0.96
    [19.10.2024] [08:53:13] [DEBUG] [QUICKAPP940]: Please Request & Get token...
    [19.10.2024] [08:53:26] [TRACE] [QUICKAPP940]: onAction: {"deviceId":940,"actionName":"UIAction","manual":true,"args":["onReleased","b1"]}[19.10.2024] [08:53:26] [TRACE] [QUICKAPP940]: UIEvent: {"elementName":"b1","eventType":"onReleased","deviceId":940,"values":[]}[19.10.2024] [08:53:26] [DEBUG] [QUICKAPP940]: {"headers":{"Content-Type":"application\/json; charset=utf-8","ETag":"W\/\"2f-qDUhhNr+EaaRaB5lJbnhcLLG5zE\"","Content-Length":"47","Api-Version":"1.3.45","Connection":"close","Date":"Sat, 19 Oct 2024 06:53:26 GMT"},"data":"{\"code\":\"3adb5f47-c307-4ad9-8a08-f7475dc8f2ed\"}","status":200}
    [19.10.2024] [08:53:26] [DEBUG] [QUICKAPP940]: table: 0xaaaaed8416d0[19.10.2024] [08:53:26]
    [DEBUG] [QUICKAPP940]: Press the action button on Dirigera then hit 'Get token'' ...
    [19.10.2024] [08:53:26] [ERROR] [QUICKAPP940]: QuickApp crashed
    [19.10.2024] [08:53:26] [ERROR] [QUICKAPP940]: Auth.lua:64: attempt to index a nil value (global 'data')
    Edit: I know your busy so no hurry.
    Edited by jimicr
    Ive seen that. Sometimes it starts to work if you wait a few minutes and press get token again. I will check for the error and give a better error message in the next version.
    Seems the hub gets in the wrong state creating/waiting for token and return error. Wait some minutes and the hub is ready to produce tokens again….
    Tried again,
    the Quickapp keeps crashing after pressing ""request token" and stops working:
    [19.10.2024] [18:32:42] [ERROR] [QUICKAPP940]: QuickApp crashed
    [19.10.2024] [18:32:42] [ERROR] [QUICKAPP940]: Auth.lua:64: attempt to index a nil value (global 'data')
    v0.97 a bit better error messages when get/request tokens.
    Some color indication when selecting temperature for a color light.
    On 10/19/2024 at 6:35 PM, jimicr said:
    Tried again,
    So I uploaded v0.97 with some better error handling but the logic is more or less unchanged.
    I tried a couple of time to install a new version and get/request token and it has worked every time.
    Try again and see if you get some error message that we can work with....
    Goodmorning,
    V0.97 works, I was able to include the Dirigera bridge and use the one dimmable driver I have.
    Thanks!
    • 1 month later...
    I'm trying the QA (0.97) on a HC3 lite and are getting this error:
    [25.11.2024] [09:25:00] [ERROR] [QUICKAPP82]: QuickApp crashed
    [25.11.2024] [09:25:00] [ERROR] [QUICKAPP82]: sha2.lua:109: at least 53-bit floating point numbers are required
    Should it also run on a HC3 lite?
    Thanks.
    Thanks.
    Yes, the infinite wisdom of Fibaro had them compile the Lua environment for 32bit integers on the HC3 Lite - which renders some QAs useless on them.
    Ex. os.time() barely fits in 32 bits and typically fail if you do arithmetic with it. Some values returned
    The sha2.lua library does some heavy arithmetics using double floats (>53 bits) that comes from the way they compiled the Lua environment -  and I don't see it possible to rewrite for 32 bits and single floats....
    • 4 weeks later...
    Hi @jgab, Do you have the Ikea Vindstyrka?
    I tested the QA, and get the humidity, lux and temp. But missing the Pm 2.5 :)
    Is it something I can do to help with integrating the Pm2.5 to?  :D
    Yes, PM2.5 will come soon...
    v0.99 attached.
    - Multiselect to select what devices should have child devices. (select and restart QA)
    - debug variable can be set
    - Rudimentary speaker support (play, pause,stop,volume)
    - PM2.5 and tVOC Childs for VINDSTYRKA
