Thnx for this quickapp! I'm trying to get it to work but am struggling a bit.
After importing the QA, setting the token, I saw in the debug that de devices were discovered, but couldn't see any 'ui dropdown'. After looking through the code, I saw it looking for a select_ID_4 dropdown. I added it manually, then the dropdown was filled with devices. I selected a light (also tried with others), restarted the QA and then get this error:
Any idea what goes wrong / how to get it working?
Thanks!
[25.04.2025] [07:41:03] [ERROR] [QUICKAPP847]: createMissingChildren:./quickApp.lua:416: attempt to index a nil value (local 'child')
Edit: when I only select the Sonos, it works and creates the sonos as child device. After rereading this topic I saw that error for dimmable light was there before, fixed but is apparently back!
Edit2: I removed the duplicate class 'ChildDimmableLight'(QwikAppChild) part in main of QA, + removed the  uiView = {} on line 172 in Devices tab of QA and now it seems to work
Edited by MathijsdB
    Ok, I uploaded a new version 1.0 in the first post. There is actually not a lot of changes I believe, but it works when I install it, and I don't get the issues you saw.
    On the other hand if it works now for you, no reason to upgrade.
    The token procedure is still a bit sensitive. If it doesn't work the first time it seems like the Dirigera hub is not keen on generating a new token for a while. Have to wait a couple of minutes or restart the hub to be able to request token.
