Guest Kees Buth
If I create a heating schuke, I can specify a time and temperatur. But does it set the setpoint to that temperature at the time I specify, or does it use that as the desired temperatue at that time, amnd take the current temperatue and the average tempincrease from full heeting in account?
So if I speecidy it should be 20 degrees at 18:00, the room ins 18 degrees and on past meassurements 1 degree increase per hour is feasable, the schedule increases the setpoint at 16:00?
Kees
