Ilyu 0
I got the Aqara T1M and was able to pair it with my Home Center 3. (via Zigbee)
In addition to my dimmer (in my room) I got 2 new devices for the main light and the ring.
Unfortunately I am only able to change the brightness and the color saturation but not the color it self.
I was wondering if it is somehow possible (with maybe a quick app?) to get some kind of color picker for the light or do I have to eventually get a aqara hub? (I dont care about effects, just want the colors)
Also I wonder if it's somehow possible to combine the 3 devices and their states. I have a button (not a switch) in my room with the dimmer behind.
I know the T1M is not able to be dimmed via the dimmer (it starts pulsating) so I have to deactivate that function fully. But I would like both of the T1M devices to be set to Off and On when I press the button in my room - is that possible?
Or the other way around would be even better: If one or both of the lights (main/ring) is on then the dimmer is on and if I press it it will switch the light off. Wierd to describe but I guess you guys get where I am at.
I can live with the button always turning on both lights. The good thing is also, that the color temp and brightness is saved and reused when I turn the light on/off with the button. (hopefully that would be the case for color aswell)
Thanks in advance!
Edit: I guess the basic logic would be having 2 QA's for the MAIN and the RING light and in the methods for turning the device on and off the following logic needs to run:
The dimmer always turns on both lights and also disconnects both zigbee connections when turning off.
With that information I would assume something like this could work:
e.g. for QA-MAIN LIGHT
Method: TURN ON
IF DIMMER == OFF{
DIMMER = ON;
RING = OFF;
}else{
MAIN = ON;
Method: TURN OFF
IF RING == ON{
MAIN = OFF;
}else{
DIMMER = OFF;
Is something like this possible or am I drifting too far?
Edited by Ilyu1 answer to this question
