Hello, I have an application where if I manually turn on a light, I need to know that the light was manually turned on and not automatically by some sensor.
But I stuck at setting and reading the value of the global variable. The value printed is always Nil. Why?
This is the only code in the LUA scene.
Help :)
6 answers to this question
Yes, that's because you need to create the global variable "GarageLightBackForced" first.
Can be done in General->Variables panel.
Help :)
You can't do this
because hub.getGlobalVariable("GarageLightBackForced") returns 2 values,
the value of the variable and the timestamp when the variable was last changed.
That means that tonumber gets 2 values as input.
tonumber can get an optional second value that is the number-base for the conversion.
Now it gets the timstamp (which is a huge number) as base and it will actually throw an error...
    Thank you for the explanation Jgab. So how can I get only the value of the variable?
    Extra parenthesis around the hub call
    I added the extra parenthesis but it continues to give me:
    I expect instead the number "2".
    Edited by Patryk Kopaczewski
