Here is a code lib to control Sonos - it's under development.
The goal is to have a code base that's easy to integrate in other projects or build custom QAs.
It's based on the local LAN API and using websockets listening for Sonos status changes - no polling(!)
Sonos commands
Example of use:
The sonos object when created does some initialization and when ready call a callback function, in this case the main of the example, logging and testing functionality.
More to come...
Here is an example of a QA that uses the library. The QA is very reactive on changes in the system.
Because the current HC3 UI model is a mess this QA is just a proof-of-concept.
The QA's type is com.fibaro.player which doesn't render in the mobile app withe the new UI...
However, it works in the web UI.
Switching to the old UI model makes the interface a bit ugly as drop-downs miss labels etc...
In the future it will hopefully be possible to create more beautiful app compatible QAs...
It's also hardcoded to the IP of my sonos, so it requires some coding to get running on your system 😉
Support will be added for grouping of players. The logic is there but not connected to the UI. The family is using the Sonos player at the moment so I'm not allowed to play with them to verify the code... ;.-)
added playModes
  • Like 5
    Here is a super simple way to integrate the library in a QA. The previous example relied on a callback function and can be a bit trickier to integrate with...
    First install
     in a separate QA file in your QA
    ...and then we define
    on top-level in our main QA file, and if everything goes fine we have an initialized self.sonos object when QuickApp:onInit() is called.
    The value assigned is a table with the ip address. Before :onInit() is called it can be difficult to get the ip from the QA's quickAppVariables.
    Thus if the value starts with "qvar:", the other part will be assumed to be the quickAppVariable where the ip address is stored. "ip" in this example.
    For now it really relies that everything is setup (that the qvar exists etc). Will add some better error handling in the future...
    Great work @jgab
