gabors 2
Hello!
I would like to ask for recommendation, advice on how to configure Roller Shutter 3 to support a valve actuator.
I have a heat recovery ventilation system that I can fully control. I have to control one of the butterfly valves 0-100% to mix inside warm air with incoming cold air to prevent freezing in the heat exchange unit.
This is the valve actuatur used:
Currently a Fibaro Roller Shutter 3 is connected to control it.The RS3 should be calibrated, but I cannot. I think because of the low power consumption of the valve actuator, but I am not sure. The actuator's power consumption is 1.5W when running and 1W then holding.
In RS3 configuration, I set parameter 155 Motor Operation Detection to 1 (W).
The operating mode (parameter 151) is set to the default Roller Blind (1).
How could I "force" calibration to work?
What other settings would you recommend to try?
Thanks in advance!
Gabor
