Hi jgab, installed the HASS Integrator, configured it and pressed „resync“. However, only some sensors are found ( and child devices created), but integrations like Twinkly or Tuya don‘t show up. Did I do something wrong here? Thanks!
    Do they show up in the popup menu list of available HASS devices?
    The fibaro popup menu s notoriously bad at updating new values, sometimes you need to reload the webpage.
    Hi jgab, yes they do show up!
    Have you done <New QA> in the first popup, and then selected the QA type in the second, and lastly, the HASS type in the third popup?
    Like described in the first post?
    and then press the "Create" button.
    If the sensors are of a type that is not supported it's possible to make your own mapping in the config file according to the instructions.
    Hi jgab, thanks - will try accordingly!
    Hello, how can I use version 0.73 (GitHub)? Above, I found version 0.72 and replaced main.lua with HASS.lua, etc. It does not work.
    You also need to update
    "utils" with Utils.lua
    "classes" with Classes.lua
    "config" with Config.lua (if you haven't done any changes to it),
    This will work if there was no changes to the UI between 0.72 and 0.75... if it was, you will need to wait for the next update.
    I will update it soon and add it to the first post, just have a lot of other stuff going on at the moment...
    Thanks, I did that with version 0.71 and 0.72. Its not working; Error:Callback error: ./include/main.lua:421: attempt to call a nil value (method 'createChild')
    • 3 weeks later...
    Hi jgab, how can I delete HASs devices from HC3, e.g. I had the Synology integration installed on HASS and after a resync I got lots of unneccessary devices (e.g. CPU temperature). When I try to delete those on HC3 nothing happens. Do I have to delete and completely reinstall the HASS Integration? Thanks! Cheers Alfons
    Edited by awlieser
