hi there,
I recently switched from a HC2 to a HC3, since the switch I'm struggling to get a simple quickapp for my sonos speakers.
I would like a quickapp just like the native sonosplayer (screenshot attached) but with the option to add one or two extra buttons to start a spotify playlist or sonos favorite.
I downloaded a lot of codes, quickapps and tried to adjust the code but im not that good in coding......
Does anybody hs a simple QA like the native sonos QA that can be adjusted?
thx!
Edited by pbtinus
typed to quick :-)
Why not just use an existing quickapp, like this one
or other existing quickapps.
Or what do you want to adjust?
    Hi, thx for the quick answer.
    I just want a simple player like the one that can be used by adding a sonos speaker as a device. (sonos player provied by fibaro)
    with the extra option to open one or two favorites by pressing a button.
    I will try the QA you mentioned, thx
    I tried the QA you mentioned and also another QA called sonos hub, both work 100% but I can not get it to work as i want.
    I now use a standard sonos player that I can adjust and add funtions , like selecting the line-in on my sonos five to play a record
    but now im struggling to get spotify working. (or playing a sonos favorite)
    The QA I would like to create is a simple player with a couple of buttons to select playlists or favorites (layout as attachment)
    Is there anybody that can help me with the correct code? (chatgpt has helped me a lot but i cant get it to work ... )
    the URI im using that doestnt work: "x-sonos-spotify:spotify:playlist:7jBDsDWvg7FXEqo91CcUpE?sid=9"
    if I change it into a single track, it works.
    complete code for the button:
    function QuickApp:hard()
        -- De URI van de Sonos-favoriet voor Tinus Soft
        local favoriteUri = "x-sonos-spotify:spotify:playlist:7jBDsDWvg7FXEqo91CcUpE?sid=9"
        -- Controleer of favoriteUri een geldige string is
        if not favoriteUri or type(favoriteUri) ~= "string" then
            print(" Ongeldige favorite URI")
            return
        -- Controleer of AVTRANSPORT_URI is ingesteld
        if not self.AVTRANSPORT_URI then
            print(" Fout: AVTRANSPORT_URI is niet ingesteld.")
            return
        -- Log de URI voor debugging
        print("📡 Verzenden van URI naar Sonos: " .. favoriteUri)
        -- Maak het XML-verzoek voor de AVTransport-service
        local function createAvTransportBody(uri)
            return string.format(
                '<u:SetAVTransportURI xmlns:u="urn:schemas-upnp-org:service:AVTransport:1">' ..
                '<InstanceID>0</InstanceID>' ..
                '<CurrentURI>%s</CurrentURI>' ..
                '<CurrentURIMetaData></CurrentURIMetaData>' ..
                '</u:SetAVTransportURI>',
                uri
        local requestBody = createAvTransportBody(favoriteUri)
        -- Verzend het verzoek naar Sonos om de URI in te stellen
        self:sendRequest(
            self.AVTRANSPORT_URI,
            '"urn:schemas-upnp-org:service:AVTransport:1#SetAVTransportURI"',
            requestBody,
            function(data)
                if data then
                    print(" Tinus Soft favorite is succesvol ingesteld!")
                    -- Controleer of de play-functie bestaat
                    if self.play and type(self.play) == "function" then
                        print("▶️ Afspelen van de playlist...")
                        self:play()
                    else
                        print("⚠️ Fout: play-functie bestaat niet of is niet aanroepbaar.")
                else
                    print("⚠️ Geen respons van Sonos bij het instellen van de favorite.")
            end,
            function(error)
                print(" Fout bij verzenden van verzoek naar Sonos: " .. tostring(error))
